I just finished building the P1 from ax84, it worked out very nicely.
My next project is something like a 5F6-A Bassman / JTM45 amp.
I'm recycling some old parts, and with the PT I'm using I wont be able to use a tube rectifier (in addition I also just dont want to use the tube rectifier).
So I want to use solid state rectification, but I'm not 100% sure how to implement it. I'm thinking I could just use 4 1n4007 diodes.
Then using diodes maybe I should use a dpdt standby switch before the diodes instead? Or does it not really matter.
And also will need to watch the voltage with SS rectification, i guess it will be considerably higher.
The next problem is the bias voltage that the 5F6A gets from an additional tap on the high voltage winding.
I need to use one of the regular HV taps. So can i just drop the voltage with a suitable resistor before the diode leading to the 2 220k grid resistors?
I saw something similar on a 1987plexi, that used SS rectification.
I'm thinking I should then also implement a bias pot before the 2 220k grid resistors since my voltages could be off?
I thought it could loke somethig like this:
Would be great to get some of your ideads and thoughts.
