Bolt on the pt lug is tight, still humming. I'm starting to get annoyed.
5e3 Debugging...
Try removing the ground wire(s) to the input jacks and installing star washers between the jack and chassis. Then carefully tighten the jacks to the chassis with a socket and ratchet. The metal switchcraft style jack can actually create a ground loop wired the way you have them. They ground naturally through the jack body. Star washers promote this grounding as well. Follow the fender 5e3 circuit diagram to the T and you'll eliminate all noise problems. I had the same issues you had on my deluxe build and these steps , plus a brass plate, ended all my trouble.
Maybe post a picture? Someone here might spot something. From experience, I personally end up messing with jacks more than any other ground connection. The input is the most sensitive area. If turning the volume knob increases the hum, then the hum must be getting in somewhere before the volume pot. Input jacks, the leads to the first stage grids, the leads off the vol. pot to the next stage grid are the usual suspects. ALso, just re-checking filter and cathode ground solder and location.
Originally posted by fsuman View PostBolt on the pt lug is tight, still humming. I'm starting to get annoyed.
Two things I would try first would be to relocate the first tube cathode bias resistor ground to a location other than the input jack. Try a longer run back to your bus wire.
Second thing that stuck me is that the grid inputs for the first tube seem to be pressed down close to the chassis. If you use a chopstick to make them run straighter off the board avoiding other wires that might help some. You might also shorten them a bit when you do that.
