Anyone have any first hand experience with both of these tremolos?
The Vibrolux 5F11:
http://www.schematicheaven.com/fende...5f11_schem.pdf
and the Tremolux 5G9:
http://www.schematicheaven.com/fende..._5g9_schem.pdf
Note that the Vibrolux uses only a single 12AX7 half and the depth pot is driven directly from the plate, whereas the Tremolux uses both halves of a 12AX7, using the second half as cathode follower buffer before the depth pot. Both wiggle the fixed bias of a push-pull 6V6 power section.
Anyway, the question really is if there is a significant tonal benefit of going to the trouble of including the cathode follower?
Note also that my inclination is to go with a LND150 for the oscillator rather than use a tube in the case that I decide to do a Vibrolux style, which would frankly be the path of least resistance, and to be preferred unless someone tells me the Vibrolux tremolo sucks.
If I went tremolux style I'd probably break down and fit another tube, although I'm obviously not a purist when it comes to using sand for oscillators and source followers.
Thanks,
Paul
The Vibrolux 5F11:
Thanks,
Paul
