I've build 4 small amps so far and had great success, but I'm still pretty green in some areas; so please bear with me as I continue to learn. I'm getting ready to build a Proluxe using Weber's layout, except I'll make it cathode biased. But I know a lot of the time I may want to use 6v6's in place of the 6L6's. I'd also use a 5y3 with 6v6's. The OT that the Weber layout calls for has a 4K primary and 2, 4, & 8 ohm taps, whereas the typical 5e3 tranny has a 6.6K primary. Here's my question: What taps are recommended to use with the different tubes? The speaker will be 8 ohm. I guess what I'm really gonna build is a deluxe with a 40w OT, and I'd like to be able to used the 2 different types of tubes. The occasions where I actually will need more than 15 watts will be pretty rare, but I'd like at least one amp that has it when I may need it. Thanks for your help!
Ken
Ken
