Iain - this is an old thread - you may get more looks by starting a new one. This thread was about one particular way to elevate the heater voltage with a DC bias voltage. It's is usually not necessary to do this and was in part an exercise for me to see how it worked.
You essentially have it right. However, you may get good results (assuming you have a reason to want to re-wire your filament) with other approaches. I would recommend first wiring your filaments in parallel and grounding the filament CT from your PT or, grounding through an artificial CT using two 100 ohm resistors. See if you get results this way first.
