Originally posted by alexradium
View Post
5F6A low volume
Originally posted by vinceg View PostI checked all the way but I not able to find the cause of the problem. About feedback resistor, before I had 27K with 16Ohm output. Leave it or change with 75K?
Originally posted by vinceg View PostUpdate
I realized I forgot to solder feedback resistor to out. Unfortunately I do not think was the problem. Now the amp has right volume but sometimes it disappears. It also seems to produce some sort of oscillation when I increase the volume control and it has background noise.
Originally posted by Enzo View PostIf an amp was working, then you do something to it, and it no longer works right, it is a safe bet the work you did was the cause. SO look especially at every part you changed, every joint you soldered.
JM2C but if you ran the amp with a 27k resistor from the 16 ohm tap before the work then leave it that way for now. Once the amp is working correctly you might consider changing some things, but you should get it back to working like it was first."Take two placebos, works twice as well." Enzo
Originally posted by alexradium View Postyou can use whatever output you want for the feedback,just use the correct value
If you had the output transformer or phase inverter leads lifted and there is any possibility that you reconnected them differently then this may cause the amp to oscillate with the feedback resistor reconnected.
As was mentioned before... The problem is almost surely a mistake in your work. Narrow your search to the work you performed."Take two placebos, works twice as well." Enzo
Originally posted by Chuck H View PostEnzo said:
The volume disappearing could be a consequence of an intermittent fault or short. It could be a crossed component lead like Helmholtz spotted, a bad solder joint or a host of other things. Since the amp worked before the problem is almost certainly a result of the work you performed. You say that the work was ONLY done on the bias supply. But you "forgot to solder feedback resistor". The feedback resistor is not part of the bias supply. So you must have done work on circuits other than the bias supply. Like Enzo said, check everything you worked on.
Originally posted by Chuck H View PostThe problem is almost surely a mistake in your work. Narrow your search to the work you performed.
Originally posted by vinceg View PostChecking heater voltage I discovered that it is 5,20V. Could it be the cause of the problem?
I'd suspect the heater voltage is a symptom rather than a cause, though, based simply on the thread discussions so far.If it still won't get loud enough, it's probably broken. - Steve Conner
Originally posted by eschertron View PostThat is definitely a problem. Heater voltage less than 90% of 6.3vac will cause issues.
One thing I forgot to say before. When I checked the voltages at the plates, in the V5 (6L6) the tester did not read the voltage immediately. In the tester's display I saw the value go up to about 400V and at the same time I heard a whistle that stopped when the tester finished the measurement. While in the V4 (6L6) the reading of about 400V was instantaneous and silent.
Originally posted by vinceg View PostWhy a symptom? The voltage of the heaters depends only on the power transformer. Maybe you mean that I also have a problem with the transformer as well as the circuit?
nosajsoldering stuff that's broken, breaking stuff that works, Yeah!
that ^^^
Plus, what else may be accidentally shorted to the PT windings? A wire whisker, or blob of solder, and now two circuits have become one - to the detriment of both. If a lot of the build was redone during your mods, then a lot of the build needs to be checked and debugged. I know my heart sinks when I contemplate tearing a bunch of stuff out just to start again, but patience and focus is really the foundation of any troubleshooting.If it still won't get loud enough, it's probably broken. - Steve Conner
