Originally posted by g1
View Post
5E7 Bandmaster
The pulled cap was tested and found good.- Own Opinions Only -
Originally posted by Helmholtz View PostWell, there are only 2 possible explanations for the low B+: Either something draws alot of current and power (and heats up after some time) - or the power supply is way too saggy.
So another idea: Are you sure that both rectifier diodes are ok and are wired correctly? If only one is operative this could explain the sagginess (does this term exist?).
I've been reluctant to run the amp for long periods of time and, therefore haven't noticed anything getting especially hot. Maybe I should just let it run for awhile and do a "heat check?"
What is your grid voltage (pin 5) at the power tubes?
You could double check idle current by the method where you record the resistance values of the OT primary halves, then measure the idle voltage across same points and calculate current.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Apologies for the delayed response. No time to work on the amp yesterday.
Originally posted by g1 View PostWhat is your grid voltage (pin 5) at the power tubes?
Pin 3: 333V
Pin 4: 337V
Pin 5: -30V
Originally posted by g1 View PostYou could double check idle current by the method where you record the resistance values of the OT primary halves, then measure the idle voltage across same points and calculate current.
I checked my Compu-Bias probe against another amp. Everything looks to be working correctly. I also plugged the Bandmaster into a dim bulb limiter and it's making the bulb glow more than I'd expect. Not a precise measurement but it supports the idea that something is drawing too much current.
It's really all about the current, but -30V seems very low. You're going to need more like -40V or -45V
Note: I felt a little silly just now calling a number that is less negative "lower" than a number that is more negative. I hope there's no confusion"Take two placebos, works twice as well." Enzo
Agree with Chuck, set your bias voltage to -40V as shown on schematic. Now what is the pin3 voltage at power tubes? Now try the bulb, is it dimmer?
You don't have to disconnect the OT wires to check the resistance, just unplug the amp and give the caps a chance to drain.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
I adjusted the bias supply voltage to vintage spec -40:
V4
Pin 3: 379V
Pin 4: 381V
Pin 5: -40V
Then adjusted some more:
V4
Pin 3: 397
Pin 4: 399
Pin 5: -44
OK, plate voltage is looking better and bulb is getting dimmer. Then I checked the cathode current using a bias probe: 25.8mA or about 10W plate dissipation. What am I missing here?
Originally posted by g1 View Postjust unplug the amp and give the caps a chance to drain."Take two placebos, works twice as well." Enzo
Originally posted by Fletcher Munson View PostI adjusted the bias supply voltage to vintage spec -40:
V4
Pin 3: 379V
Pin 4: 381V
Pin 5: -40V
V4
Pin 3: 397
Pin 4: 399
Pin 5: -44
OK, plate voltage is looking better and bulb is getting dimmer. Then I checked the cathode current using a bias probe: 25.8mA or about 10W plate dissipation. What am I missing here?"Take two placebos, works twice as well." Enzo
Actually, with the tubes off, there is no current path through the transformer, so other than for safety, discharging B+ caps ought not make a difference. PLEASE DO NOT DO THIS, but if you were to pull the power tubes out, a resistance reading across the transformer primary would be possible even with B+ present.Education is what you're left with after you have forgotten what you have learned.
V4
Pin 3: 379V
Pin 4: 381V
Pin 5: -40V
V4
Pin 3: 397
Pin 4: 399
Pin 5: -44
I assume that the voltage readings were taken without the bulb limiter?
A question: When you reversed the OT primary leads, did you notice a change of gain? As reversing the leads turns positive feedback into negative feedback and vice versa, there should be a marked difference in power amp gain. The correct wiring is the one with the lower gain, meaning negative feedback.- Own Opinions Only -
