I'm still trying to work out how best to set up my 5F6-a clone. I'm a little confused and wonder if someone could clarify a few points for me.
1: When setting up the bias, should I really be just setting the current to 25ma for cold, 35ma for medium or 45mA for hot. I have read these figures a number of times for 6L6GC tubes, and I guess they are for a fixed plate voltage, is that right? Would I be right in saying what I'm really after is a range of plate dissipation powers? Say around 30 Watts for a 6L6GC (what range do you guys work with?). If that's the case, then I guess if I change my rectifier for a solid state device, I will increase my voltage, and to keep the same plate power, have to reduce the current. Is that right?
2: When I bias my amp, I put a 4.1 Ohm 25 watt resistor in between the cathode and the ground of both the power tubes (so I get the sum of both currents through this resistor - I have an order in for 2*1 ohm resistors, but in the mean time I use the lowest resistor I have). I then measure the voltage across this and tweak the bias pot to get the right current. So please correct me if you see me doing something wrong, but I think when I get 0.282 volts across my 4.1 ohm resistor, I have 34.4mA through each tube. (ie 0.282/4.1 = 68.8mA from both tubes, ie 34.4 mA each.) Since at this bias level I have 480Volts on the plates of my tubes, I think this bias is set up for 480*0.0344 = 16.5 watts.
FYI to attain this bias current I have -48.9vdc at the bias point shown on the original schematic.
I guess you will now see why I'm so confused, and thinking I've got something above wrong
(okay I realise it might be more than one thing - so please help out a thickie, who's trying to understand it). Or maybe I just haven't biased the amp enough, and this low power setting is why I get early break-up from the bass notes, when played through a closed back cabinet.
3: I'm of the impression that higher plate voltage, when biased correctly, will give greater headroom (ie. more clean sound). Is that right?
4: I believe increasing the main filter caps. helps firm up the bass response of the amp. What effect do you hear if you increase the pre-amp filter capacitor?
Thanks for your help here guys.
A little confused Jester.
![Confused](https://music-electronics-forum.com/core/images/smilies/confused.png)
![Roll Eyes (Sarcastic)](https://music-electronics-forum.com/core/images/smilies/rolleyes.png)
