I've got a yellow board Blues Jr. on the bench with a blown screen resistor. Schematic calls out 100 ohm 1/2 watt fireproof. I don't have any of that size on hand, so before I order something up wanted to see if others stick to the original or use something else. I've read theories that the 1/2 watt size was intended as a sort of protection mechanism to burn open with a shorted tube. If so I wish they had made them solderable from the top of the board without having to remove almost everything to change it out.
TIA
Greg
Schem https://www.thetubestore.com/lib/the...-Schematic.pdf
TIA
Greg
