Peavey 5150 Combo - Tone Controls + Post not functioning
  • Peavey 5150 Combo - Tone Controls + Post not functioning
    Hey everyone!
    Bought this second hand, long story short its now mine and I'm trying to make the best of it. The nearest tech is about 6 hours away so I've been trying to figure this out myself and I've hit a wall, hopefully you guys can help me.
    So first time I turned it on there was a massive wave crashing sound when going in and out of standby, as well as crackles (no playing because of this - immediately powered off). Opened up the chassis and saw C68 had been leaking, so I had changed all 8 electrolytic caps on the main board. Popped everything back in and further realized the tone controls don't work and neither does the post lead (or rhythm) - the pre control functions though (lead and rhythm). So to further explain the tone controls have zero function at all, the post lead/rhythm have an odd change, with very small change (say from 0-0.5) it'll actually drop volume and become very fizzy then another tiny adjustment up (0.6 to 10) and its a large jump but almost seems like if I plugged into the return jack, almost no gain and the post control doesn't change if its on 0.6 or 10.
    I busted out the oscilloscope to trace the signal and there's a sign wave present at nearly every step in the schematic until we reach the wiper of the post controls (there is signal in the treble wiper and the tone controls do shape the wave). I have signal INTO the pot but nothing leaving the pot. So I figured perhaps something is wrong with the pots, had a spare 1MA that I know is good, no change, peavey pot showed fine when tested out of circuit. Have continuity to ground on the lug, checked the tone stack for continuity to ground.
    I tested voltage on the pre amp tubes and they are as follows (following the tube layout per the schematic)
    V1a 154/170
    V1b 191/225
    V2a 206/310
    V2b 168/175
    V5b 148/187
    V5a 193/247
    V3b 304 (v2+)
    V3a 252/285
    V4a 300/320
    V4b 287310
    Not even sure what to check or where to go.
    Here is a link to the schematic and board layout:
    https://el34world.com/charts/Schemat..._212_combo.pdf
      I would guess that the "clamp" function of Q1 is shorting the signal after the post controls to ground, assuming CR1 or CR2 isn't shorted. I think Q1 is supposed to mute the amp for a moment during channel switching, but am not completely sure.
        Interesting I never would have thought to check further downstream since I lost it at the pot! I'll give it a shot and report back
