Fender Blues Jr Weak Reverb
  • Fender Blues Jr Weak Reverb
    The installed tank is an Accutronics 8EB2C1B
    I have a FBJ tweed, whose reverb does not kick in until the pot is past 7. I tried a couple of different tanks I had (none were for a FBJ) and they all behaved like the installed tank.
    I tried a FBJ at a local store and it's reverb behaves as desired across the range of the pot. That tank is a Belton BS3EB2C1B.
    I am reading that these two different models are both used in FBJ but the Belton's perform better than the Accutronics.
    I cannot find specs or anyone selling the Belton BS3EB2C1B.
    Also I know that the comparison amp at the store is not exactly the same amp. The one I am looking at has a fat switch and mini pot for the fat switch, the one at the store has no mini pot.
    I am also reading that there have been mods to address FBJ reverb issues such as a pot taper change.
    Too much to consume and make sense of. What are your thoughts?
    Thank you, Mark
    Click image for larger version  Name:	20240618_140317.jpg Views:	0 Size:	2.57 MB ID:	1000583 Click image for larger version  Name:	20240619_091354.jpg Views:	0 Size:	2.29 MB ID:	1000581 Click image for larger version  Name:	20240618_164717.jpg Views:	0 Size:	1.82 MB ID:	1000582
    It may be silly & obvious, but be certain you have the input & output cables connected properly . So unless it's really true these amps have weak reverb which I tend to doubt, I guess it's time to look into the reverb drive/regeneration circuit. It might be a good idea for starters to just replace the TL072. You could measure voltages on the IC to look for approx 0V on pins 4-7 and 1-3. If there is any appreciable offset from 0V, that could prove the IC is bad. Also, be certain there is supply voltage of +15V on pin8 and -15V on pin4.
    From that point you'd be looking at signal path issues, eg: weak electrolytic coupling caps, etc. Though it does seem unlikely.
    Glrn
      A mod? If so, chances are there may be other mods or some mod that is affecting the reverb circuit.
        If you swapped tanks and it's still the same, a swap to a Belton is not going to solve your problem. Since it is a blues jr, there are many mods to this and your problem lies with that mostly done incorrectly. See if that pot is jumpered underneath, then it would be a hacked mod. I am guess the tl072 also as was said.
          Turns out it was modded. That mini pot below the FAT switch is part of a "presence" mod and a lot of parts on the board looked replaced. I also did not see any op-amps on the board.
          Should have taken a photo to post here but given all the mods, the owner took it back without further investigation.
          Swapping the pan cables in/out helped to slightly improve the reverb depth. But still far from how it should be.
          Thank you all!
            Here is a 'snip' of the reverb circuit with test voltages.
            casinolevant levant casino
