This Mini Brute has distorted output when playing a guitar.
With distortion set off, sounds are cracky, static, distorted and jumpy output, starting at low volume and on up. Person I bought it from thought it had a bad speaker.
I found...
no DC on output
this amp has same issue when connected to an external speaker
this amp's speaker is fine connected to a different amp
this amp's main output (preamp out) sounds fine connected to a different amp
I see a clean sine wave at this amp output (at all volume levels), when injecting a 1K signal at the input. See scope shot
So it seems the preamp section and speaker are fine in this amp. But why the clean 1K output signal on the scope? Is it because it is a constant signal unlike a guitar signal?
The scope image and testing was done with the volume around 3, tone controls at mid point and distortion set to OFF.
Any suggestions and does anyone have the schematic for the power amp section of this amp?
Thank you, Mark
![Click image for larger version
I found...
no DC on output
Thank you, Mark
