Hi all!! I'd love to get some input and ideas on which direction to go.
I have an Ashdown Fallen Angel 60 which is the first version (no DSP). I have already had to replace the PT (which was succesfull).
Now the problem is, while playing a while back the volume cut down to about half. I tried different power tubes (EL-34s) and it was the same. I've swapped out the Pre's and the PI with known good 12AX7s,, same.
I know from reading and research that these have been plagued with bad transformers which is how I was led to this site. I suspected the OT mabey going south. I don't know how to check the OT except to use a multi and check the resistance from the center to the outside taps on the primary. I'm getting 138 on one side and 128 on the other. According to some research, this is acceptable (5-10% common).
There is no brown or burnt components that I can see. There are two resistors that are not "cylindrical" (don't know if they were to begin with) they read " W22 1KO 5%" and are in the power section. I have downloaded schematics at work and will post them soon. they are R36 and R59.
The shame is that I really like the amp and it's versatility, 2 1/2 channels, 2 master volumes, effects loop, 2x12 config.
Any other ideas? I like to learn thing by doing them myself so I will not be taking it to a "tech" (plus I'm WAY too "overly thrifty" (read,,, cheap).
T
Thanks for your time and consideration!!!
T
