Having just recently repaired a brand new Fender Twin Reverb combo amp, where the complaint was 'Play Low E string loudly on guitar causes loud transients. After moving it up onto my checkout bench, powering it up, then taking it out of Standby, first thing I heard was substantial hum with both volume controls fully CCW. And loose Fuse Holder. So, I'd be taking this apart to get the chassis out of the cabinet. But first, I gave it a good whack on top of the cabinet, which reacted with loud barking noises with every whack. YUP. Been down this road before.
Pulled the rear upper panel off, then carefully depressed the stiff Bear Trap clamps releasing each of the power tubes, set them in order in my holding box. Fetched my X-Acto knife with a #11 blade installed, and one pin at a time, scraped the sides of each pin all around the circumference to yield clean surface on each pin. Pushed the tubes back into place and powered back up. Pounding on the top of the cabinet this time was quiet without the loud 'objection' to such vibration-inducing blows.
What I haven't really come up with is a good proper-sized round shaft that has a grit-surface to it. Blank Drill Rod, #61 size (0.039" dia) for the Preamp tubes and #43 size (0.089" dia) would be suitable sizes. What I haven't figured out is how to turn those smooth surfaces into a fine harden grit surface as though it was a suitable grit one might have on emery cloth. Would sand-blasting the blank drill rod yield such a surface? I'd first want to round off the end of the drill rod's blunt end so it easily slips into the tube socket's mating contacts to be cleaned and burnished.
I've used wooden shank Q-Tips as cleaning rods, dipped into Caig DeOxit in the past, along with back end of those two drill bit sizes, fitted into a Starrett Pin Vise.
