I have an Ampeg SVT III Pro. It sounds distorted and choppy, as if the MOSFETs were poorly polarized.
I have seen a difference with respect to the original scheme, the resistors R28, R29 and R30 are 1Kohm instead of 47ohm. But it seems like this has been going on since it left the factory and it worked fine.
The problem is that through the 0.47ohm 5W resistors R32, R33,R34,R35,R36,R37,R38 and R39 there is 0.0mV and even if I move the trimmer it is not able to go above 1mV.
I have removed the MOSFETs and checked with a semiconductor analyzer and they seem to be fine.
I don't understand where I can have the polarization problem. What could be happening?
