This is a two input version. See page 3 of attached schematic.
Plug inserted only to input one, tip is 1M to ground
Plug inserted only to input two, tip is 137K to ground (unless there is a plug also inserted into input one, then it is 1M to ground.
Issue I have is a very distorted input one, and a better only slightly distorted input two.
Both inputs feed pin 7 of V1 through a 68K resistor and a 1M ground resistor.
Scope pics below show input one and input two, 1K injected signal, volume set at one.
Traynor-Guitarmate-YGM3-Schematic (1).pdf
