Marshall MG15 CDR Strange Issue
  • Marshall MG15 CDR Strange Issue
    Had very weak fizzy distorted output. I traced the issue to 4558 IC5A (clean signal at pin 3, bad signal at pin 1).
    Replaced IC5 with a new 4558, amp sounded great but after three minutes of playing audio drops and is replaced by a hum.
    Pattern... turn amp off, wait, turn amp on. Sounds fine for a few minutes and issue returns.
    I have replaced all filter caps, C33, C34, C31, C32, C27, C28. I have a stable V with -14.9 and +14.7 on the rails. However the issue persists, after three minutes of playing the audio drops and is replaced by a hum, while V remains constant.
    Simpler scenario... Amp ON, nothing plugged into the input, both volume pots at zero. No sound then after three minutes a hum starts.
    Would love suggestions on this one. Schematic I am using is attached. Thank you
    Marshall+MG15CDR.pdf
    Click image for larger version  Name:	20240719_164644.jpg Views:	0 Size:	1.50 MB ID:	1002210
    After sound dies, check for DC voltage at all op-amp output pins. Maybe a missing ground reference somewhere.
      The two filter capacitors don't look right ... Click image for larger version
Name:	Screenshot 2024-08-04 at 15.34.57.png
ID:	1002214 are they the correct way around?
        Originally posted by Jon Snell View Post
        The two filter capacitors don't look right ... Click image for larger version  Name:	Screenshot 2024-08-04 at 15.34.57.png Views:	13 Size:	939.8 KB ID:	1002214 are they the correct way around?
        Now that I look at the schematic it looks like one is backwards,
        Deneme bonusu veren siteler
        betticket istanbulbahis
