Hi to all,
I have experience in electronics and tube amplifier repair, but all these semi-digital electronics confuse me a bit
This is the story of this alchemist :
I restored power supply back on it, the amplifier was working fine but with a lot of hum
I increased the filter capacitors in the while (220*2/100*2 500v)
Changed rectifier diode and capacitor 68000uf.
The amplifier was fine.
Playing today, after some day that as i said amp was ok, I heard a short and A small spark circuit somewhere and the amp got stuck on the clean channel
Only clean channel commands work, the relative switches treble crunch deep are ok
Digital effects work
I've checked voltage and they seem ok, so the power supply seems to be good. I'm afraid that some component in the relay circuit has blown
Tomorrow I will recheck the digital board from which the inputs for the channel change relays start (the one where the 7905/08 transistors are present, etc
I replaced q1/q2 with two transistors 2n3904
I'm trying everything, there are no burn marks, the only component that was blown is r4 apparently
I replaced it
Maybe I was tired and stressed and I got the wrong value
A little while ago I was reading is 1k
I'm afraid I used a superior value.
Any idea is wellcome
I replaced it
