Weird issue... The amp is working after re-tensioning the PI socket. It would cut out moving the PI tube . But strangely , the Treble pot is now acting as a " master volume " control and the mid and bass pots have zero effect on the signal. The MV and Gain pots work normal . treble on 0 and the amp has no signal. Anyone seen this issue ?? The amp has never been apart. Possibly a bad Treble pot? I can loosen the nut and move it and signal doesnt cut out so I think the solder joints are ok at the pot. I tried clean/ lube on the treble pot .
Orange OR15 SCH 115V-230V.pdf Orange OR15 SCH 115V-230V.pdf
