The existing input jack had all pads and traces broken or lifted. Jack tested good. Re-wired it, not a proud soldering moment.
Amp now has a buzz noise. Present on both preamp channels, but if those volume are dialed down to zero there is no buzz on the master volume turned up. Also no buzz if nothing is plugged into the input jack.
I am also seeing 35 to 40 mV DC on the output, even with all volume pots at zero and nothing plugged into the input jack.
Help! Thank you..
Images show before to after...
![Click image for larger version
Help! Thank you..
