Replacing rca jacks on sf twin reverbs
  • Replacing rca jacks on sf twin reverbs
    I had to replace the rca jacks on a sf Twin Reverb 100 watts with mv. The replacements did not include lock washers, so I thought they were unnecessary. Well, if you don't use them the reverb doesn't work. I wrote out a long post asking you guys to help me figure it out, then I thought about those washers and put them in. Voila! I guess the ground doesn't connect well without them. I pass this info on.
    Thanks.
      I'll also mention that oxidization at those star washers can create hum issues in the reverb circuit.
        I find that, during refurbishment of an amp, cleaning and tightening of mechanical ground points is a significant requirement to reestablish good performance.
          Yup to all.
            What is an "mv" jack?
              I think he means a Silverface Twin reverb with master volume.
                Yes, sorry I was unclear.
                Strangely, when I used my rca to 1/4 in cable to test reverb in and out I good signal without the washers. So signal was going into and out of the tank but there was no reverb. Everything tested ok but there was no reverb. That's when I turned to you guys. That little tech on my shoulder told me to put the washers in, even if it made no sense.
                  Thanks.
                  Now I see, this is a MV Twin and the RCA jacks had to be replaced.
                  The reverb send jack gets its ground via the chassis only.
                  As this is the output of a low impedance (8 Ohm) power amp, it's essential that you have a good, low resistance ground connection here.
