Got a Backstar Artist (single 6L6GC) on bench with no output (apart from usual very quiet hum) from either the normal input or via FX return. With the master vol all the way up you can just hear the input signal if the room is quiet!
It's tricky as there's no schematic available, and a lot of surface mount stuff!
But I have probed voltages and usefully there are test points marked on the main board with expected voltages. What I've found is that all the voltages are as marked or very close, but the high voltages collapse as soon as a jack plug is inserted into the input (which you have to do or the amp is muted).
For example TP 10 (anode of one of the triodes in ECC83/12AX7) is marked 200V and is 203V with nothing in input socket, but as soon as I insert a jack into input socket the voltage drops to 89V. Similar results for other high voltage points e.g. TP5 marked 390V (expect this is anode for the 6LG) drops to 295V when a jack inserted, TP6 (290V so probably a screen voltage for 6L6) drops to 124V.
Both the 6L6 and the ECC83 test fine in my tester, and just in case the 6L6 was doing something weird when in the amp (my tester has max 250V anode voltage) I tried a known good 6L6GC with same result of collapsing high tension supply.
Lots of chopsticking failed to find any cause, though owner who sold me the amp said it was intermittent no sound problem so I'm optimistic!
This would be relatively simple with a schematic so all I can do is ask for tips for finding where in chain the voltage is collapsing as soon as the power valve draws a current. Maybe someone has seen this behaviour on the same amp or one of its cousins (the Backstair Studio 10 series)? Absent a schematic best I can do is post a good photo of the board.
The only clue I've found so far is that this behaviour at every test point happens whether the standby switch is set to have the amp off standby or on standby, and I can't measure any volts either side of the standby switch!
Thanks in advance
Thanks in advance
