Are load settings properly matched both amp to power station and power station to speaker?
Marshall 1959rr no play with Fryette power station
Originally posted by tdlunsfo View Post
This would be a 16ohm resistor. Bias Current is one of those inline socket adapters that puts your ammeter between the plate and B+. So I guess "plate current" instead of "bias".
Is the dummy load part of the power station working? What does it read for a load when NOT bypassed?
I see lack of tube current and blown screen resistors and think unloaded amp (or too high load impedance).Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
- Likes 3
Originally posted by tdlunsfo View PostWhile playing I did get some slight noise on the waveform but it never went into full blown oscillation. I was actually measuring bias current/ voltage, B+, screen while testing on the dummy load, here are the numbers:
B+: 398
Screen; 311
Bias Current: 4mA
Bias Voltage: -45
Same amp settings but Power Station bypassed:
B+: 356
Screen; 326
Bias Current: 92mA
Bias Voltage: -42
4mA is not a typo above. I checked muliple tubes and same. I chalked it up to something the power station was doing."I took a photo of my ohm meter... It didn't help." Enzo 8/20/22
Originally posted by g1 View PostIs the dummy load part of the power station working? What does it read for a load when NOT bypassed?
It's a little unclear to me how to test to make sure it's working correctly. I guess I can hook an ohmmeter up to the amp in jack on the back of the power station to see what it reads.
Above you show voltages with the Power Station in the circuit and then bypassed. Are these voltages measured while the amp is conducting signal? They don't make any sense to me. Nothing about the Power Station should cause the plate voltage to rise and the screen voltage to drop. Please recheck those numbers to confirm that your plate and screen voltages are indeed different ONLY with the Pwer Station in the circuit WITHOUT the amp conducting signal.
EDIT: Another possibility... I'm recalling a build I did some years ago where I couldn't seem to find EL34's that would hold up in rather vanilla circuit. Screens kept popping. I went through three pairs before one finally held up. I had purchased two different pairs from a vendor I will no longer use (both JJ but of different suffixes) and one pair from Ruby. As far as I can tell to this day the problem was poorly tested new tubes that were faulty as the last tubes to go in (the Ruby's) are still in the amp and working fine years later. Just illustrating that coincidences like this can happen.Last edited by Chuck H; 09-21-2024, 11:31 AM."Take two placebos, works twice as well." Enzo
B+: 398
Screen; 311
Bias Current: 4mA
Bias Voltage: -45
B+: 356
Screen; 326
Bias Current: 92mA
Bias Voltage: -42
If idling, was it checked for ultrasonic oscillation whilst in that mode, with those loads?
If idling, could the test be repeated but with the valve in V3 LTP phase splitter removed? (That should eliminate the ability of the output stage to oscillate).My band:- http://www.youtube.com/user/RedwingBand
- Likes 2
Yep. This. Helmholtz called out the possibility of oscillation back in post 5 and I haven't seen it clearly addressed yet.
Maybe I don't have enough experience with this but I don't understand how oscillation would cause the plate voltage to rise while the screen voltage drops and measured current through the tubes to drop to almost nothing. The results in that test seem too weird to be anything but a failing tube.?."Take two placebos, works twice as well." Enzo
Yes. And wiggle things around when you do that to see if there are any intermittent faults in the connections. And...
Originally posted by Greg Robinson View Post
That's definitely suspicious. Seems like the Fryette power station has a faulty reactive load."Take two placebos, works twice as well." Enzo
