First I would try disconnecting the jfet Q3. Either of the legs connected to R42.
Fender Rumble 500 Power Supply Issue
I don’t recall their pot details. On larger dia pots that have the mechanical terminals riveted to the resistance wafer, I have had to generally tap the rivet between a suitable center punch pin mounted in a vice and further flatten the other side of the terminal revit to restore solid mounting and restoring conductivity.Logic is an organized way of going wrong with confidence
Q3 shorts R42 but brings the signal line much closer to ground, so may be acting as a mute.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Originally posted by Bryan View Post... I get nothing at Pin 8 on U3
This is the power supply pin U3.
Originally posted by Bryan View PostIs there a reason I only get signal on one side of C18? I get signal between R37 and C18 but not C18 and R43.
I'm using 100 hz. That's what it says in the schematic.
Anyway, I'm good on the Overdrive circuit now too. All is working. My bad resoldering on U4 pin 11.
I still get the balance shift on the rails when I plug in the fan. I get -12v instead of -10v. Maybe it is a bad zener D26. But it is now making much better sounds than when it arrived.
