MESA Express 5:50 crackling noise
  • MESA Express 5:50 crackling noise
    Hi,
    So I have here a Mesa Express 5:50 which has that annoying crackling noise. Not loud but even with all controls at zero you can still hear it at the background.
    I narrowed down the problem to V3B at the FX loop. When C31 is shorted to ground the noise is gone. With pin 2 shorted the noise is still there. What I did so far:
    1/ tried different tubes - NO change
    2/ suspected leaky cap C31 - tried a new one - NO change
    3/ lifted one end of C30 - NO change
    4/ resoldered all components around V3B - NO change
    By this time I ran out of ideas. Any suggestions would be appreciated.
    Another thing is switching Standby OFF produces a loud pop. I fixed that by installing a 100nf/630V cap across the Standby toggle switch but I have the feeling the actual problem was masked and not solved but this can wait for now.
    Express 525-550 schem.pdf
    Pin 2 doesn't belong to V3B. Do you mean pin 7?
    R59 might be bad.
      Thanks for the quick reply.
      Yes, I meant pin7.
      R59 might be bad.
      I'll replace it and report back.
        My thought process with rustling noise is pre amp valves, then power valves
        But if it is more of a crackle, sizzling bacon then I usually find that it is plate or cathode resistors that have had a hard life (high volt drops), couple caps also but less common and easy to diagnose with a voltmeter, resistor body contact with other traces / PCB (esp . boogie) and coming off another thread recently corrosive glue / silicone goopy.
        HTH
          Problem was solved by replacing the R59 as Helmholtz suggested. Thanks for your help. That saved me time replacing all other components around V3B.
