Hello wise ones. I ask kindly for your guidance again.
Initially, amp was cutting out. Bad solder joints, due to the common low voltage section resistors and diodes against the board. Rebuilt that section with parts flown away from the board as usual.
15v supplies are good. And on all ICs
Amp has no reverb. TP36 is + 15.6. Should be - for Reverb on. Right? Unless this too is only with the footswitch? If so that’s just throwing me off.
Audio TP’s. Are good before the reverb tank. And 0mv after. Signal present at output of tank. Cable good. As soon as you plug cable to tank it pulls the signal down.
is Q2 on? And it’s turned on by U3? Or am I way off in the weeds again? I feel like I am! Haha
I’d like to know how U3 switches pin 1 from + to -
So I can understand what it needs or is missing.
And I’m researching how the JFET switches on currently.
To confuse things more. I can hear, from the speaker. The tank crash when I shake it. So like the return is fine.
Which really doesn’t add up with the other info.
Checked continuity of the shield on the input cable to
WJ2 and U2-pin 2 as I read in a post from Enzo, that would kill the driver. But it checked good.
I’ve replaced both U2 and U3 without change.
Thanks in advance!!
Thanks in advance!!
