I have a '68 Fender VC. The volume pot is acting sort of erratic, slight increase in volume from 1-4 then drops off suddenly and stays low for the rest of the sweep with a very minor increase when pegged at 10. With the volume at 4 (loudest I can get it) the treble and bass pots decrease the volume as they are turned up. No noticeable change in tone through the sweep, just decreases volume.
A little background on the amp: The circuit board has been replaced. Original circuit design with a few minor changes to for reliability, bias, and safety. This was all done about 2 years ago with light to medium use since then. I also just replaced the cap can. Tubes are relatively new, but I have no spares on hand to try swapping. It seems like more of a circuit problem than a tube issue to me though.
Any help is appreciated.
I have a DMM and soldering tools. I have some experience with the amp, so I will know how to fix the issue once I know what it is, but I'm not so good at the diagnosis part. I removed/checked all of the pots that seem affected and they tested alright.
