VT-Phasor Twin Tremolo
    I see what looks to be a hole in the side of the device where an LED might have been inserted, or is that just a reflection in the picture? I can't tell for sure.
      Now that you mention it, I think that might actually be the LED itself, see latest pic. I'm also noticing that the black plastic part has glue around the bottom. originally I was thinking I might have to remove the PCB from the chassis and remove a ton of solder to see what's in/under there, it might be a matter of scoring the glue and prying it up.
        I think I count 10 traces going to it, which is what I had expected for 4 LDR's and a single LED. Yes, it's possible the plastic is just a cover. Don't force it in case it is not, it should come off easily if it's just a cover.
        Those stubs may be test points.
          The dome covers the LED and four LRDs, and it excludes light from the LDRs when the LED is off. It's a common arrangement for similar circuits. The inside of the dome can be matte or reflective, depending on the amount of light bounce needed. Here's a Uni-Vibe clone effect pedal, with and without a reflective dome.
Name:	Screenshot 2025-01-07 075238.png
ID:	1009124 Click image for larger version
Name:	Screenshot 2025-01-07 075338.png
            I think Mauman called it right. Looking at schematics, this seems pretty much like a clone of the Uni-Vibe, but mixing NPN and PNP (though there may be versions of the Uni-Vibe that did that too)
            VT
            Click image for larger version  Name:	VTtrem.jpg Views:	0 Size:	90.9 KB ID:	1009128
            Uni-Vibe (from https://revolutiondeux.blogspot.com/...easy-vibe.html)
            Click image for larger version  Name:	univibe trem.jpg Views:	0 Size:	59.1 KB ID:	1009129
