This is a weird one
Typical cheap amp from the sixties, 10" speaker and a 6" high frequency little speaker, 35WZ5, two 50L6, and two 12AX7's
Heaters powered by line voltage as usual, taps for the 12AX7 filaments, but it has a high voltage tap going to the rectifier tap
Can't find a schematic, only pix.
I have everything working great and dead quiet, just need to find the right isolation trans
It's a shame, I have a little power trans from an old Radio Shack/Tandy reciever that has the voltages I need, is the exact size but doesn't have the current for the heaters.
It works, but eventually it would melt down.
Don't suppose anyone has seen a similiar schematic?
Question about isolation trans mounting.
I usually have room on the chassis to mount an iso trans, not on this amp.
When you guys mount a trans in the cabinet, do you run the AC power into the amp/fuse first, then to the iso trans out to the amp, or run the ac to the iso trans first, then to the amp?
Thanks.
Thanks.
