Bench Power Supply?
  • Bench Power Supply?
    After countless years my bench PS (Sencore AC Powerite) meter needle has failed, making the unit useless. Below is a pic of the unit in the OFF state, the needle should all the way "left" at zero.
    Looking for recommendations where I can dial up AC and monitor AC and Current. Maybe a dual display.
    Watching a needle movement has become second nature to me but I wonder if a digital readout would make sense to quickly detect bad high current situations.
    Thank you.
    I would carefully take the meter apart and see if it can be repaired. Often times it's just a static charge and a good cleaning will make it work. Sometimes it's a stuck/mechanical issue and a cleaning and slight bit of lube will make it work again.
      If you are interested in taking a shot at fixing it, I have seen newsgroup discussions in which people fixed analog meter movements. Many found a small bit of debris that was interfering with the needle movement.
      Have you tried twiddling the zero setting adjustment screw to determine if that mechanism is snagging the needle?
        aside from those great mechanical suggestions, it might be something simple in the needle driver circuit.
          https://pacifictv.ca/schematics/sencorepr57data.pdf
          its super simple!
          As to using a fancy digital meter here is a discussion on the issues : https://www.eevblog.com/forum/beginn...er-for-variac/
          Click image for larger version  Name:	sencor meter.jpg Views:	0 Size:	24.4 KB ID:	1010088
            Something odd is going on. Today the needle has reseated itself back to normal.
            Past couple of days it was resting below zero and I would have to tap on the panel and it would reset to zero. Also a few times yesterday it had pegged a few times when it should not, and then it was in complete failure mode.
            Today it is acting normal.
              The symptoms could indicate that there is a bit of something in the meter movement that cause the needle mechanism to jam. It's possible that it will never happen again so it could be a good idea to just keep using the instrument for now and maybe it will never happen again. That Sencore is a nice instrument and is much more advanced than just using a variable transformer with a voltage/Current meter.
                The old saying, when trying to fix a meter movement, it's not working, once you get done, it's never going to work now. Unless you are a jeweler, good luck.
                  The couple of times I have tried to do anything to a meter needle were a disaster.
