Hello all
I have a svt pro 7 in for the usual problem
I tested to confirm issues very random switches off and on again
I removed the board to`replace U2 , This has been replaced before and a heatsink glued on to it
Replaced for 3A2065 which is an uprated chip
Refitted the board tested working Screwed up for testing the following day
Following day, Dead !! Tried a heat gun on the u2 area, came on ,
Removed the board replaced all 3 electrolytics . As i fitted U2 on a socket, I put a new one in, still the same Refitted and still dead until you apply a little heat
I have used the heatgun and freezer spray, Once its on, no freezing will make it switch offpower supply-xx.pdf
Checked all soldering - all ok
I have tried the Heat/freezer on secondary side
Many thanks in advance
Mr A
Mr A
