My 1985 ibanez fl9 lights up when i engage the pedal but does not generates the effect. Should c130 and c131 electrolytics caps be replaced? Any suggestions?
Ibanez fl9 flanger lights up but no effect
So you get dry signal through either engaged or disengaged but no flange effect?
Here is service manual. There is a troubleshooting flow chart. http://www.mojotronics.com/images/FL9.pdf
Originally posted by Jquijano View PostMy 1985 ibanez fl9 lights up when i engage the pedal but does not generates the effect. Should c130 and c131 electrolytics caps be replaced? Any suggestions?
If they are low value, the oscillator will run too fast and produce a flanger on steroids!Support for Fender, Laney, Marshall, Mesa, VOX and many more. https://jonsnell.co.uk
Well i replaced both c130 and c131 electrolytic caps with 2 47uf 16 volts caps. It started ocillating and sounding more as a chorus with some jet sound in the background. I do hear some crakling or dirt noise in the background also. How do i get rid of this noise and get more flange sound as lenny kravitz gets in are you gonna go my way?
Originally posted by glebert View PostSo you get dry signal through either engaged or disengaged but no flange effect?
Im still getting dry signal after replacing c130 and c131 yellow elecrolytic caps. Should i now change the diode?
- Likes 1
Originally posted by Jquijano View PostCant i do it with a multimeter? Whats the function of the diode below those 2 caps?
Maybe you have a bad solder connection that is getting jiggled every time you work on the board. You could try resoldering it.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
- Likes 1
