This JC-120 came to me with both outputs blown in one channel. Everything on the amp board "seemed" to test ok in circuit when compared to the good board, so I replaced the drivers 2SC1624 and 2SA814 with MJE15032 and 15033 and the outputs with MJ15024s in both channels. Powered up with a dim bulb tester while checking the bias voltage across one 0.3 ohm emitter resistor in each channel, and noted that the bias was rising very fast in the "bad" channel.
So I shut it down, rechecked the board and found that two of the 100 ohm 1/4W fusible resistors were measuring around 45 ohms each out of circuit. I pulled them and put in two new 100 ohm resistors and tried powering up again. The bias in the bad channel measures around 50mV, even with the current being limited by a 40W bulb. I also observed that the replacement 100 ohm resistor get very hot fast, when viewed through a thermal camera.
I took a break from it for the night, but will take another look in the a.m. If anyone has any suggestions, I'm all ears. Thanks.
