Finished servicing one of these recently and it sounded fantastic with chassis on bench. Moved everything into hallway to reassemble it into cabinet and replace panels, reconnect reverb and speakers. Flicked it on to admire it again, to be met with a loud motor boating noise and the occasional shriek! Sighed and moved it into room where I store amps, intending to strip it down again soon to find the new fault (it had never motorboat before).
Day or so later I decided to start work on it again. While it was in storage room powered it up and it sounded fine with no sign of motor boating. I don't trust intermittent faults so decided to disassemble it and try to provoke whatever had caused the fault. Removed the chassis and on bench went through all the power supply capacitors including the crucial one supplying HT to V1. They are all pretty new F&T caps and all were perfect. Amp sounded fine.
Scratched my head and took chassis back in to hallway to reassemble amp. Powered it up, off standby, and it began motor boating. At this point light dawned and I shut off power at wall to the wifi router standing right behind the amp. Golden silence!
Did a bit of experimenting and amp could pick up some interference from the router even when it was a couple of feet away. Maybe Fender should have used one or two metal shields on the preamp 12AX7s?
May help anyone here with a mysterious fault, and save you all the time I spent looking in the wrong place. Check for possible interference sources including routers and 'smart' devices!
