I’m looking at a working (though will need new supply electrolytics) WEM Dominator. Want to identify/test all the valves and the 2 EL84s and one of the preamp valves all have same Mullard Blackburn 1978 date. Probably original to amp as this model first appeared in WEM’s 1978 catalogue.
I can’t inspect the other two ECC83s as instead of the usual sprung screening can twisting onto lugs, they are in a tight fitting thin metal sheath. Interestingly this sheath is connected to a grounding ring around the valve base via a soldered wire.
Has anyone come across this? How can I get the valves out the screens without risking damage to valves or inconvenience of breaking off the grounding wire?
Thanks for any advice.
