Peavey XXX
  • Peavey XXX
    Working on a 100w XXX head. The amp wont switch to the clean channel. It does go from Crunch to Lead . Its not the switch .
    The Clean Led doesnt light ( has -17v at it) . I dont hear a relay click when going to Clean mode.
    I have -17vdc at CR3 .
    I dont have a fsw for it - its some weird 5 pin Din thing .
    Where should I start measuring?
    Peavey-XXX-Schematic.pdf
    Would Q8 or Q10 cause the relay / Led not to work ? They are in the area called Clean bypass
      As Enzo used to say, its usually the over stressed JFETs used in the channel switch /mute circuit that fail (Q2 and Q12 = jfet J174)
      OR it could be a bad relay and resistor like here:
      https://forums.peavey.com/viewtopic.php?t=49554
        Thanks !!! R86 is new . i think i have some J174 here
          Would a J175 be an ok sub for a 174 ??
            A J174 has a Drain - Source ON resistance of 85 Ohms, the J175 is 125 Ohms.
            Probably won't make any difference but Mouser stock J174 (if you don't want to lose points at the show for fitting the wrong component).
              Peavey doesnt seem to think so (see below and attached) but they look similar, maybe test?
Name:	Peavey JFET list.jpg
                J174 - 176 are no longer manufactured. There are many equivalents; jfet_j174_j175_interfet-2888180.pdf
                Take a look at the specifications. They are from the same die, just have slightly different specifications. All are basically interchangeable with Peaveys' requirements.Click image for larger version  Name:	Screenshot 2025-03-30 at 09.04.02.png Views:	0 Size:	175.0 KB ID:	1012286
                  Thanks... ill try swapping the j174
                    Replaced Q2 ..Q12 . No change
                    After a long search its a dead end on that relay . Google ..ebay.....cant sign in to Peavy forum ..etc...
                    Anyone know where to get one?
                    peavey bom = K2 = 70460097 , 12v DPDT . Part number on relay is FRT2H-S
                    Cant find one anywhere
                      You have the wrong part number. It's 71322378. On the BOM, the part number comes first, then the component identifier. The spacing on their BOMs makes it look like the part number is after the identifier, but it's not. It's a 12VDC non-latching DPDT relay,
                      Click image for larger version  Name:	image.png Views:	0 Size:	23.0 KB ID:	1012344
                      It's either going to be an Omron G6S or G5V. I don't recall what spacing you need on it. Check the datasheets on the two options below and please let us know.
                      Possibly this one: https://www.mouser.com/ProductDetail...uv0QsFzA%3D%3D
                      or this one: https://www.mouser.com/ProductDetail...fCr9o1Dw%3D%3D
                      Edit: Just found the datasheet for the FRT2H relay. Looks like 5mm spacing so that will make your relay Omron G5V-2-H1-DC12.
                        Thanks !!!!!
