Whaddya' think....?
Boutique expensive amp with cracked broken tube socket.
Replaced socket, powers up fine until output tubes are installed then blows fuse a couple seconds after power up, probably milliseconds..
Tried different output tubes, tried different rectifier, yes socket is wired correctly, it uses pins 1 & 6 as tie ins so I made sure to try output tubes that don't have 1 or 6....same thing.
i'd be bummed if it was my amp.
