Greetings to all,
I'm in a fix here. I've had this mixer in for over 2 weeks now (some of that time is waiting on parts).
Original problem was that the Monitor side of the amp went dead. I found and replaced Output Transistor on the monitor side, also the SAC187.
Last time this was tested (prior to the SAC187 replacement), the Main side worked great - still no monitor. I then found the SAC187 bad - and ordered it. Replaced it this evening. Plugged it all back in, and now when the power is applied (thru a Sencore), loud pop in speaker - and it shuts down.
It's not blowing fuses anymore though. I'm totally stumped!! Why would I have power on the Main before - and not now? I've checked and rechecked my wiring.....marked prior to removal....and unless I'm making the same mistake over and over, cannot find a fault.
The owner is wanting this back tomorrow too......yikes.
The Output board is a 304S.
Thanks in advance,
ChancesR
Thanks in advance,
ChancesR
