I've been tracking down and fixing most of the rattles in my new Crate V-18 amp but there is this one last one that has me baffled a bit.
It sounds like it might be the EL84 output tubes rattling internally. I switched between a pair of 1999 and 2007 Sovtek tubes with no change. I just put in a pair of JJ's which seemed to have improved things a lot.
What is weird is that I get the rattle/buzz on notes between low F# and B, but only if the master volume is higher than 6. Even if the gain is set very low. If I turn the gain up higher the rattle/buzz is not there if I leave the MV at 6 or lower.
The power amp section of this amp is a bit strange. What would be bias splitters are 470k resistors rather than the more common values of 220k or 100k. But this is a cathode biased amp so I guess that are just considered to be the grid load. The grid stoppers are 10k, which seems a bit high to me. I usually use something between 1k5 and 5k7 on EL84's. Anything higher than that seems to make the amp sound a bit dull to my ears.
Any thoughts here would be appreciated. Prayers, too!
Steve Ahola
Steve Ahola
