Fender Princeton Chorus, black knob, 1995, everything works except the treble control has no tone change from 0-10. Is this a cap, or a pot...? It has no affect except a slight scratchiness, even though it's been cleaned. Also the bass is very boomy from 4-10. Are these related...?
Treble Control Dead...!!
Originally posted by Enzo View PostProbably. Get out your ohm meter and check the pot.
The treble pot still does not appear to affect volume in any way, at least not noticeable, but I haven't played it loud either. Something much more noticeable and a possible clue is that the midrange and bass controls are greatly affecting volume. They actually shut the volume completely off when counter-clockwise to 0. I don't think any amps do that.......is that a clear clue, and does that still point to C20 as the culprit??
Pretty normal for no sound when ALL EQ controls are at zero.
Pots should never go to infinity. Legs 1 and 3 are the ends. They are the largest resistance that should be measured. The center leg - leg 2 - should measure from zero up to that max from either end.
Th R value should vary smoothly from zero all the way up to the max. It is not sufficient that it just changes.Education is what you're left with after you have forgotten what you have learned.
Originally posted by Enzo View PostPretty normal for no sound when ALL EQ controls are at zero.
****That's no sound if either mid or bass are counterclockwise to 0 - don't think that's normal.
*****I probably don't have the proper range on my digital meter, so it looked like infinity, but is probably just very high - I'm understanding the pins o.k.
does the signal have treble or no treble at all? i seem to have no treble in my signal at the moment because i intentionally bypassed a cap leading to the treble control (it doesnt appear to be working) this left me with very little treble, and the control acts as a volume, which obviously isnt happening happening to you due to the design. I know jack about this stuff but first thing i would try is replacing the cap. Just an idea.
Originally posted by antiunderscores View Postdoes the signal have treble or no treble at all? i seem to have no treble in my signal at the moment because i intentionally bypassed a cap leading to the treble control (it doesnt appear to be working) this left me with very little treble, and the control acts as a volume, which obviously isnt happening happening to you due to the design. I know jack about this stuff but first thing i would try is replacing the cap. Just an idea.
Originally posted by wolf1419 View PostI appear to have limited high end, but not as if the tone was all the way to 0, probably = to if it were set on about 3-4 and fixed right there. No changes using the treble pot(tested o.k.), so I ordered some caps and an inexpensive, simple, wide range Mastech 390-375 capacitance meter (0.1pf-20kuf) for this job and future repairs. I'll let you know when I achieve success.
