the reverb on my fender ultra chorus don't work on both channel. somebody have an answer.
fender ultra chorus reverb don't work
First, look at the reverb pan, the long box with springs inside. Are any of the wires inside broken off? Disconnect the two cable from the jacks on it. Now measure resistance across each empty jack. One should measuer pretty low resistance and one about 100-200 ohms. Open readings mean a bad reverb pan.Education is what you're left with after you have forgotten what you have learned.
If the springs are detached, you can sometimes fiddle with the little hooks until they're reattached. If its the little wires to the transducer, you can carefully (it's as thin as headphone wire) strip and resolder it...I've even taken the springs from a broken tank and put them in a working tank that was missing the springs!
