5150 help
  • 5150 help
    how do you get inside to change the fuses? I dont wanna start ripping this thing apart. any help with what screws?
    The rear grille has to come off first, of course. The chassis is held in by the four screws through the rubber feet. Then the chassis slides out the open rear. SOmetimes the front part of the chassis is a little wedged under the front panel. If you have that problem, then two screws in through each side holds the front panel, so remove them to free that panel, and so free the amp chassis
