60 cycle. Very similar to the noise from a guitar cord not plugged into an instrument. Max hum is at "5" on each channel. When turned all the way down, hum disapears. When turned all the way up hum is almost goes away completely. The input jacks are shorting properly. Power supply is ok.
If the Master is turned down, and either channel turned all the way up, the amp is usable if the Master is used for the volume control.
The leads from the 68k input pairs go to unshielded wires which go under the fiberboard to the tube socket. Could it be as simple as using shielded wire from the resistors to the tube sockets?
Anybody with a similar experience?
