Hi all. Noob alert, I just signed up. I took the time to search through the forum before asking for help from anyone, but I can't find anything related.
Here's the problem:
Bought a used HRD 410 about a month ago. Amp is about 4 years old, and was virtually immaculate when I bought it.
Switching from my drive channel to my clean channel. The clean channel volume will blast well above the level where I have it set, then drop to the level I have it set, where it stays. Adjusting the volume, either up or down, during the "loud" period does nothing, even if I cut it to 0. The volume stays at the "loud" level until it drops into "quiet" level on its own, when the volume control works again.
The problem is intermittent. Sometimes it switches correctly, sometimes it just has a quick volume pop, sometimes it stays in "loud" mode for long enough for me to walk over to my amp, tweak the volume a few times, scratch my head, try it again, then it goes to "quiet" mode.
Mind you, this is during band practice, so it's not like I'm trying to make a 60-watt tube amp behave itself at low volume. I typically run at about 3-4 on the drive channel and 2-3 on the clean.
I am sure the issue is isolated to the amp.
Never had anythign remotely similar with any other amps I've owned, so I'm not sure what's going on. Any help would would be appreciated.
Here's the problem:
