I've got a 2275-65 Musicman on my bench that is not putting out the sound it should-like 10 on volume and 10 on master give me maybe sound like a 1 on my deluxe reverb....This is one with the schematics that are just about worthless due to the fuzzy copies that are available on the net.
the OT has been replaced with an off the shelf unit at about 6600 impedance. I'm guessing this is way too high an impedance, does anybody know what the correct impedance should be? Like half that?
the voltages seem to be right on the power tubes in both high (700V) and low (450V) settings. The power tubes bias up at .5v as they should.
This is the model with the 12AX7 phase inverter. The voltages seem low to me: the first triode is 205V on the plate and 1.47 V on the cathode, the PI triode is 275V on the plate, 17.5V at the grid and 41V at the cathode.
I've tried moving the LM307's around and that didn't seem to make a difference.
It the most likely cause the OT? Am I missing something obvious?
thanks!
thanks!
