I've replaced my el34's in my jcm 2000 and there is a problem. The right set of tubes biased just fine to 85mv, then when I switched the multimeter to the left bias needle, the meter starts to read VOLTS not mv, between 20 and 30! Obviously there is too much voltage going to the left set of tubes. Is this a bad resistor or something else?
jcm 2000 bias problem
There are two 1 ohm current sense resistors from the cathode to ground. One for each side and one of them is most likely open. These resistors are where the voltages your reading comes from. If one is open the tube will go into thermal runnaway and will glow cherry red and hopefully blow the fuse Rick was referring to. If you take your meter and read from the Cathode pin 8 to ground chassis and it's open, that's your problem.KB
Hello, i realize this is a very old thread but i was just wondering if this guy ever figured out what was going on im having the exact same problem only its the right side, same thing between 20 and 30 volts, is this a serious problem or an easy fix? i bought this amp used and used it a couple months before i changed the tubes and had no problems other than the clean channel being pretty quiet and the gain knob on the clean channel crackels a little bit when i turn it.
Well certainly the whole problem is not so much how poorly it's designed more than the fact that it doesn't respond very well to bad tubes out of box or failing tubes. Fuses that are supposed to protect don't blow before other parts do. I've seen plate load resistors fry and blow the whole trace off of the board to open screen resistors and current sense resistors open but the source is usually a bad tube. If you are red plating monitor the bias voltage on pin 5 and see if it's drops when it red plates. If it does than I'd suspect a leaking coupling cap after the PI. Also check the 1 ohm resistors and the plate load resistors and verify they are ok.KB
