I just built a homebrew amp and tried to shoehorn a custom reverb circuit into it. It uses a BF Fender type Send: a paralleled 12AT7 driver with a 2k2//25uF cathode, 022921 Reverb tranny connected to the plates (tranny red wire), 1M grid load. Input is through a 560pF coupler off of the second gain stage. Pan is an Accutronics 4AB3C1B. I have 382vdc supply (rev tranny blue wire), 376vdc plates, 7.6vdc cathode. Black wire is to ground, green wire is to the Reverb Send jack.
When I input a 880Hz/100mV signal (true rms) to the amp and turn up the Volume to a reasonable level I have ~160mVac signal at the 12AT7 grid. Then I have ~3.1Vac at the plates but then only ~52mVac at the Reverb Send jack (I can barely even measure it). Then I get nothing out of the pan.
Also, when I scope the 12AT7 plates the line is jumping/wobbling up and down (even with no signal, the horizontal line is jumping/wobbling...and not just a little).
Another thing...when I measure tip-to-sleeve of the Reverb tranny Input I get a very low value...like around 1ohm...its so low I can't really get a good measurement...I just know it's more than the leads by about 1 ohm. This is an unused pan I bought new years ago. It looks mint.
Last question: Is it OK to run this with no pan? It's an OT so I didn't think running it with no load was kosher...but I think I may have accidentally done it.
Any help appreciated. Thanks.
Couple of pics...a face only a mother (or father) could love.
