Tomorrow I am going to try and clean up and repopulate my "new" cab. This one is ancient with a low, port on the back. The front grill baffle is loose so I need to tighten it up somehow. Do I need to take off the side-running mounting wood strips inside just to tighten things up?
Also the back, unlike the rest of the cab which seems to be plywood, is a freaki' HEAVY slab of particle board. I'm considering a trip to the wood supplier, for something different, and would field good advice first.
The tolex has been thrashed should I replace it? I've got dealer status at Mojo Supply but ripping off the old stuff doesn't look fun.
ALSO: as I have two other 4x12s and not 12 speakers yet, how would covering the two bottom holes sound for now? I suspect four 12' drivers are too much cone for the typical stack-box - thus two or three speakers- might prove optimal.
