I have a 6100LM im in the process of of fixing up. I found some blown fuses and some of which weren't rated properly. I want to find the correct replacement fuses so I found the appropriate schematics but I have a few questions if anyone would mind helping me out.
PSU Circuit
http://www.drtube.com/schematics/mar...6100-65-04.pdf
Power Amp Circuit
http://www.drtube.com/schematics/mar...6100-63-04.pdf
F408 of the PSU Circuit lists a T2A - 230V and a T4A - 115V, which do I need? I assume I should use the T4A - 115v being a U.S. resident and running 120v?
Some of these fuses are labeled 20mm and glass, but not all are specific, should all of these fuses be glass and 20mm?
Also, what about the capital letter "T" before the amp rating of some of these fuses, from what I've gathered the "T" means Slow-Blow?
Thank You.
PSU Circuit
Power Amp Circuit
Thank You.
