I don't like working on modern tube amps made with everything on cheap circuit boards and jumper strips, but two friends are having what appears to be the same problem with their amps.
One is an Ampeg Jet II J12T, which is a 2X EL84 combo, and the other is an Ampeg Reverberocket R 12R with 2X EL 34's. Both are from the late 90's -SLM product.
Both play fine initially, but once they've been on for a bit at stage volume, the sound cuts to a low level with distortion.
Anybody had similar problems with these?
